Finally! My STS IC project is complete.
I'm going to dyno it one of these days, if I don't sell the truck before hand. This kit was designed to be an easy install, lower priced alternitive to whats out there currently. 1 cooler must have its mounting tabs ground down and the cooler re-attached. A plastic panel under the bottom part of the fan shroud is cut out & the bottom fan shroud must be trimmed. I've email the Moderators about sponsor info but no answer. his is not a massive intercooler, it needs to flow alot of air but as you guys know that have an STS, our air is not as hot when it gets to the engine. So a smaller hi-flow intercooler is where I am. I can make a model that is larger in both hight & width, but don't want to build in lag for no performance gains.
mike
mike
