finally boosted but....
Old Oct 22, 2013 | 01:32 PM
  #51
gamble686's Avatar
Originally Posted by smokeshow
If the truck were here I could have it diagnosed and tuned in a day.
Well darnie get it to the man!!
Old Oct 22, 2013 | 06:14 PM
  #52
darnie's Avatar
The truck is parked and wont be driven tillni get it figured out i have hardly driven it at all so no worries there i just wanna have it running right so ill wait. Im gunna try whatever i can possibly think of tomorrow i got all day and thats my goal
Old Oct 22, 2013 | 10:26 PM
  #53
FarmTruc's Avatar
Performance Trucks Sponsor
Tuning is the easy part. Making sure everything else is 100% is the key, along with having access to a good diagnostic shop.
Scans that look terrible isn't always a fkd up tune.
The PCM is simply doing what it's told to do.
Old Oct 22, 2013 | 11:12 PM
  #54
darnie's Avatar
Yea. I switched the map sensor back so far its idling alot better but didnt have a scaner so all i could see was the afr. What should my plugs be gapped to? Running the ngk t6 plugs, im going to pull them and check all the gaps tomorrow aswell
Old Oct 23, 2013 | 12:06 AM
  #55
darnie's Avatar
i understand that. my biggest issue is i got a garage and the internet. so its all trial and error so im attempting to fix it before i have to trailer it 200 miles to a shop...tomorrow i plan on trying to scan it again, try a different MAF sensor, check the plug gap, then also spray starting fluid again around everything.
the things that have changed when i did the swap....
extended MAF wiring.
new plugs.
new msd wires.
new 2bar map
new injectors.
i never took off the intake manifold but i did add the lines for the gauges and what not. form what ive gathered the idling issue cant be a exhaust leak. and i know the o2 sensors are good because there reading and they have thrown lean codes on both banks. AFR seems decent at idle. kinda rich at WOT and as soon as i let off the gas it hits 20 and i have to feather it to keep it running. also the fuel pressure is about 66psi or so... figure thats pretty good?
Old Oct 23, 2013 | 03:39 PM
  #56
gamble686's Avatar
Well at this point I am seriously doubting it is the tune. The LTFT's are still maxxed out at 25 with the new spark plugs and both tunes. We will be trying a different MAF and check again for exhaust leaks. I don't know why this is coming to mind, but could it be an issue with the stock Valley Cover? Also I am thinking it might be the head gaskets? They are still stock.
Old Oct 23, 2013 | 03:55 PM
  #57
gamble686's Avatar
Here are logs with the new spark plugs and both tunes one of which should have 20% more fuel.
File Type: hpl
File Type: hpl
Old Oct 23, 2013 | 04:54 PM
  #58
smokeshow's Avatar
Mod with training wheels
Try just unplugging the MAF. Use something to keep the IAT connected though. Gotta do it sloppy if you can't edit the tune to diagnose.
Old Oct 23, 2013 | 05:27 PM
  #59
gamble686's Avatar
Well we just found a clip on the rear of the intake from the vacuum line to the brake canister that was broken. Repaired that and we are gonna try the first tune and the new MAP and see what happens. We will try a new MAF next.
Old Oct 23, 2013 | 05:33 PM
  #60
AkSSS's Avatar
Not that this would cause all your problems, but if you are intercooled, are you still using the stock iat senor in the maf? If so it would be advised to get on in the charge pipe after your I/c. They are cheap and will help in the tuning process.
Just trying to help.
