finally boosted but....
Old Oct 3, 2013 | 12:27 AM
  #21
oakley6575's Avatar
Originally Posted by smokeshow
Saposto...I find this word intriguing.
My exact thought
Buy HPT and don't look back. It will be the best purchase so far..
Old Oct 3, 2013 | 07:13 AM
  #22
Chevy_King1500's Avatar
change WG spring(s) I'm running a 1.5 and 3 lb and can make 8lbs of booost
get your baseline with WG only and then hook up your boost controller
Old Oct 3, 2013 | 07:26 AM
  #23
03sierraslt's Avatar
Did Nelson setup the tune for the 2bar sensor?
Old Oct 3, 2013 | 07:40 AM
  #24
05GMC4.8's Avatar
Originally Posted by darnie
i dont have hp/efi im having nelsons run my tuning. i got a buddie in town that can take logs maybe tomorrow i will get some done. as for speed density i was going to run it but they cant do it over mail order tune so im stuck right now with what i got unfortunately.
If you're not tuned for the 2 bar speed density, put the stock map sensor back in.
Old Oct 3, 2013 | 07:43 AM
  #25
You can be 2bar Maf enabled but it doesnt sound like he is, this is what I am trying to find out is if he is tuned for the 2bar sensor.
Old Oct 3, 2013 | 08:48 AM
  #26
darnie's Avatar
according to allen it was tuned for the 2-bar. i have both i can try and swap the old on back in if need be?
Old Oct 3, 2013 | 08:49 AM
  #27
darnie's Avatar
sorry. my bad
Bring the truck to Tucson some time and we can get it running SD.
this is my plan just gotta wait till the government figures out what there gunna do with ous. cant take any days off, no OT and no sick time... sucks
Old Oct 3, 2013 | 10:27 AM
  #28
darnie's Avatar
boost issue seems to be fixed. i checked around for leaks and truck still acting weird with the AFR. but i switched to the 1-bar and am going to drive up to get some gas and see how she does.
Old Oct 3, 2013 | 10:32 AM
  #29
smokeshow's Avatar
Mod with training wheels
It takes some effort to calibrate a MAF sensor for a blow-through turbo setup. Airflow dynamics through the sensor change as boost goes up too, so that compounds the difficulty. Tuning for that setup via mail order isn't going to be a quick process.
Old Oct 3, 2013 | 10:44 AM
  #30
Choda's Avatar
What spring did u put in
Did u vent the top port of the wg
How many psi are u seeing at wot?
