A FEW questions
I have a 2002 RCSB Z71 5.3 with 4L60E and 3.73 Limited Slip. I have done quite a bit to the motor and I was wondering what kind of dyno numbers I might get. I have a powerdyne blower with 9 psi (fixing to be 12), 42 lb injectors, a custom dyno tune, ram air hood, 255 LPH Fuel Pump, Corvette Servo and Shift Kit, and I just purchased a 2002 Z06 cam, intake, and heads along with a set of pacesetter longtubes. So I have a FEW questions?
I was checking around and I found out that for a blower motor I need to not go with Z06 heads but with plain 6.0 heads so that I can lower the compression ratio, is this right?
Also I ordered a pulley to take my truck to 12 PSI will it withstand this?
The heads I have did not come with rocker arms can I use the orginal ones off my 5.3?
If I use these heads should I change anything with them like springs, push rods, etc?
What about a 90mm TB upgrade? Or can I use my stock?
Are my 42lb injectors big enough?
What kind of HP do think I can get with this?
I know that this is alot of questions but I hope that yall can help me out. After I do this I am going to have the truck retuned on dyno. Thank yall so much for your time.
TAPyvehc93
Sep 12, 2015 08:19 PM
