few pulls on the dyno for the SD tune...
Old Apr 6, 2009 | 08:10 PM
05crew's Avatar
Default few pulls on the dyno for the SD tune...
got the truck up to ryan at RPM today. after we put the 2bar in and got the driveabilty good we made a few pulls. at 15* timing and 8psi it made 510rwhp.., i was thing it would make a little more. but we are going to hit it with the meth and more boost on tueday. trying to go for 14psi or so.
Old Apr 6, 2009 | 08:24 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
very nice for 8lbs!
TrickTurbo's Avatar
Truck Sponsor
Not bad for a first outing.
Old Apr 6, 2009 | 08:34 PM
05crew's Avatar
thanks trever1t, and trick.. hope to make a little over 650 or so. well see. with the meth and about 19* of timeing should not be a big deal....love the set up...alot better than the STS.
Old Apr 6, 2009 | 08:44 PM
2ktransam's Avatar
Nice numbers. Which turbo is that? I'm hoping to get some better results out of my butt turbo with a TC76 soon.
Old Apr 6, 2009 | 08:47 PM
NGA PLZ's Avatar
what are the specs on your truck? Nice numbers.
Old Apr 6, 2009 | 09:14 PM
05crew's Avatar
for the most part spec are in the sig.....it a tc76,
Old Apr 6, 2009 | 09:25 PM
2ktransam's Avatar
I was hoping that was the turbo you were using. Which exhaust housing are you using? Do you have the graph to post up? I would like to see your curve with that turbo.
Old Apr 6, 2009 | 09:30 PM
05crew's Avatar
.96.. it spools fast as hell. i might go to a bigger one... and i will have a vid and graph soon when it makes its last numbers... hoping to get to 650 or so...
Old Apr 6, 2009 | 09:34 PM
2ktransam's Avatar
I'm going to try the .81 and .96 on mine. I think I will end up with the .81 since it's a rear mount but I don't want to choke it up top.
