fast spool 5.3?
Old Aug 16, 2024 | 01:35 PM
twigy's Avatar
I have a 7675 on my truck spool is very fast but I'm also tapped out at like 650-700 hp with E85. I wish I would have done an 80+ now.
Old Aug 17, 2024 | 08:45 AM
IIGW's Avatar
5 Year Member
any specs on what youre truck engine is?
Old Aug 19, 2024 | 05:27 PM
Fullpower's Avatar
I have a 7675 on my truck spool is very fast but ...................
How'd you get the turbo to light of QUICK ? Did it take some fine tuning to get the SPOOL you wanted ?
Care to show screenshot of your spark timing table ?
What torque converter are you using ?
. Thank you.
Old Aug 22, 2024 | 12:10 PM
twigy's Avatar
Fully forged 5.3, Circle D Triple Disk 3400 Stall, LS1 Heads with valve job, BTR Stage 2 cam, custom cold side and exhaust. My build thread is on here few post below if you wanna look at it. I'm on 17lbs at 19 degrees so semi-conservative about to turn it the rest of the way up to 20lbs and I should be mid to high 700s.
Old Sep 2, 2024 | 04:54 PM
Fullpower's Avatar
F I'm on 17lbs at 19 degrees so semi-conservative
What fuel are you using @ 19 degrees spark on 17 PSI manifold pressure?
Are you running straight methanol ?
06murder
Jul 12, 2024 12:25 PM
fctry286
Nov 27, 2014 01:11 AM
GMCtrk
May 1, 2009 11:35 AM
SSCUSTOM6.0
Oct 24, 2007 08:09 AM
parish8
34
Jan 8, 2004 11:56 PM
