fast 90 or carb'd with eblow
Old Aug 2, 2007 | 11:31 PM
  #31
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Originally Posted by 2004SSS
yes that is correct on sizing but imo some thing need more vacuum an dyou wont get enough out of the 1/4 tap . for all of the stuff i have on my truck i tapped 4 1.4 npt in the back of the intake elbow
i found out my old problem with my bov was because it wasnt getting good enough vac/boost signal to stay closed when under boost.
with quicks set up you need quite a few vac lines
if he does the dual intank pumps, one shoul dbe run on a hobbs switch, the fpr needs one, a boost gauge, a bov, i needed one for my evap ,i also needed two for my map sensors( 2 bar for intake and 2 bar for meth ) and one tap pre blowerr for the pcv.
I've heard that a lot -- "poor vacuum signal" -- I've even seen guys put a fuel filter in a vac line to "clean it up". IMO vacuum is vacuum. Chances are you had a small leak that was corrected when you went to a single line. Vacuum isn't consumed or diluted and it propagates on the femtosecond scale.
I run everything Quik is talking about running off 2 vacuum ports -- and used to run more off the two stock ports in the truck manifold. The only issue I ever had was when I blew a vac line off at 15psi
Old Aug 3, 2007 | 12:03 AM
  #32
Quik's Avatar
5 year bitches!
alot of good info and thanks guys. makes me want to start this asap but this will take a little longer at the moment
Old Aug 3, 2007 | 06:53 AM
  #33
silver-mod-o's Avatar
Hunt&Fisherator
If you are planning on twins (which I am assuming) I'd go with a GMPP or Vic with a 1K CFM 4bbl downdraft TB with an elbow or a hat pretty much like the Wood Hauler is/was running on his truck. I think it'd be a much cleaner looking setup as well, and flow like crazy...
Old Aug 28, 2007 | 11:51 AM
  #34
Quik's Avatar
5 year bitches!
been doing some researching and found that the carb'd intake cant hold its own against a typical composite intake. this was also on a NA motor.
does anyone have before and after dyno numbers for the carb'd vs composite intake
also realize boost makes it power thru the turbos and not as much as the heads/intake
Skip Fix
22
Jul 9, 2016 07:08 PM
murderedSS
27
Oct 12, 2015 11:13 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
