fast 90 or carb'd with eblow
Old Aug 1, 2007 | 09:25 PM
  #21
Quik's Avatar
5 year bitches!
now has anyone had any issues at all with brackets for the cables? or how about the vaccum ports?
Old Aug 1, 2007 | 09:53 PM
  #22
2004SSS's Avatar
vacuum lines all get tapped into th eback of the intake elbow. the cable bracket comes with the edelbrock it.
Old Aug 1, 2007 | 09:59 PM
  #23
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Why is 8altng running an IW dampener?
Old Aug 1, 2007 | 11:29 PM
  #24
Quik's Avatar
5 year bitches!
so i take i need to drill/tap for the ports?
Old Aug 1, 2007 | 11:30 PM
  #25
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Originally Posted by nightrunner
isnt parish pushing well over that in the fairmont? on a truck intake
stockers are one single piece. A FAST is a 3 piece.
Old Aug 1, 2007 | 11:31 PM
  #26
I AM A MOTHERF*CKER
The Vic itself comes with a 1/2 vac port on one of the rear runners and a ... want to say 1/4" up at the "carb plate". You can run everything you need of off those two.
Old Aug 2, 2007 | 07:11 PM
  #27
2004SSS's Avatar
yes that is correct on sizing but imo some thing need more vacuum an dyou wont get enough out of the 1/4 tap . for all of the stuff i have on my truck i tapped 4 1.4 npt in the back of the intake elbow
i found out my old problem with my bov was because it wasnt getting good enough vac/boost signal to stay closed when under boost.
with quicks set up you need quite a few vac lines
if he does the dual intank pumps, one shoul dbe run on a hobbs switch, the fpr needs one, a boost gauge, a bov, i needed one for my evap ,i also needed two for my map sensors( 2 bar for intake and 2 bar for meth ) and one tap pre blowerr for the pcv.
Old Aug 2, 2007 | 08:46 PM
  #28
Slowhawk's Avatar
LS1Tech Sponsor
Why not? Guess we have more secret's
With a Carb intake you have to custum stuff. No biggie. I ussually make the cable brackets, drill more ports in the intake for vacuum ect.
Old Aug 2, 2007 | 08:50 PM
  #29
TURBHOE's Avatar
wow thats a lot of crap needing vacuum. one good thing for me i don't need vacuum for my brakes.
  #30
1slow01Z71's Avatar
you can tell me
