FAST 2 bar map sensor help with specs
Old Nov 29, 2012 | 01:32 PM
silverz28camaro's Avatar
Default FAST 2 bar map sensor help with specs
I have a FAST 2 bar part number 307008. Trying to find the scaling and offset data for it so I can get it tuned right.
Any one have this info or at least a good starting point, will be using hp tuners.
I called FAST , they acted like they didn't know what I needed, put on hold for 20 mins then they hung or or we comhow got disconnected
Thanks for any input
Old Nov 29, 2012 | 02:14 PM
nonnieselman's Avatar
have you tried connecting it and trying different values ~190 to get the Key on Engine off KPA reading the same?
Old Nov 29, 2012 | 02:24 PM
carbongmc's Avatar
Good luck with this is all I can say. I see FAST treating this just like their injectors. Something they will sell to the masses, but have ZERO info on! I bought a set of FAST 65lb injectors, called them for the injector data, and their response was to tune off an LS2 stock injector and go from there because they dont have it.
Old Nov 29, 2012 | 06:43 PM
Haven't tried anything yet, but friend is coming down from st.louis to help me with this, he said try to get the specs on the sensor if possible. I'm sure we'll figure it out and if we have to do a step by step in the efi live tutorial as well.
Look at this one, its a decent price and fits OEM location unlike the fast brand, AND has all the data needed to help get things rolling...maybe I should go this route??
ELECTRONICS
lucas287
31
Jan 12, 2021 06:18 AM
chvy=power
Sep 8, 2015 11:06 AM
Ls3silverado
Jul 31, 2015 04:22 PM
jrplz
Jul 9, 2015 12:07 AM
