Failure of STS PCV checkvalve?
Old Jul 18, 2005 | 04:20 PM
TG02Z71's Avatar
Default Failure of STS PCV checkvalve?
Anyone know what would happen if the PCV check valve failed?
What would be the systoms?
Old Jul 18, 2005 | 04:50 PM
TURBHOE's Avatar
alot of blow by and may shoot your dip stick out motor may smoke when in high rpm/boost.
Old Jul 19, 2005 | 09:38 AM
TG02Z71's Avatar
Looks like mine is working properly then. No smoke show here!
Old Jul 19, 2005 | 10:35 AM
Mort's Avatar
Cool
You can test it if you are worried or as part of periodic maintenance.
STS - '99 -'04 Chevy Truck Instruction Manual
46. ELECTRICAL SYSTEM TESTS: With the engine running , use a jumper wire to jump across the terminals of the Pressure Switch near the throttle body. You should hear the oil pump get louder and be able to feel the PCV Switch Valve click. Next jumper across the Pressure Switch terminals on the oil pump inlet. This should cause the buzzer alarm to sound inside the cab.
Old Jul 19, 2005 | 10:52 AM
TG02Z71's Avatar
Sound easy enough, I'll have to give it a try on my lunch.
Thanks Jim.
Tim
lucas287
31
Jan 12, 2021 06:18 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
Aaron Arceneaux
Dec 21, 2015 02:54 PM
nabozny21
Oct 17, 2015 07:47 PM
JordanH
Oct 3, 2015 03:59 PM
