F1A procharger build has begun
Old Nov 6, 2009 | 06:34 PM
hemidup's Avatar
3 bolt's on the crank pulley? Could end up like this one did.
Attached Thumbnails F1A procharger build has begun-hp-acceleration-003.jpg   F1A procharger build has begun-hp-acceleration-002.jpg
Old Nov 7, 2009 | 08:52 AM
Mort's Avatar
Wow...that's not good
Old Nov 9, 2009 | 11:08 AM
the_reaper's Avatar
ok I will bite.... Hemi what the hell was that carnage from. looks to be a old V-belt setup.
Old Nov 9, 2009 | 01:55 PM
1989k1500's Avatar
88mph?
Old Nov 9, 2009 | 03:50 PM
hemidup's Avatar
Yup, your correct. It came apart after a 9.8x pass@138 mph. That steel drive pulley only spun an altenator, not a blower. The engine was a 605 cubed Hemi making 805hp/800ft lbs, tq. An F1A series blower is capable of making up to a 1000 hp at the same rpm as the 605. My concern is how much that Procharger aluminum crank pulley can handle only using 3 bolts. We have a few, off the wall Procharger builds going on at this time and none use less than 6 bolts on the drive pulley. Just my .02
Old Nov 9, 2009 | 06:20 PM
jerry"n.l.c"'s Avatar
loox good
Old Nov 9, 2009 | 06:47 PM
fastlt1's Avatar
12 Second Club
More specs on the motor, please. I've never seen a F1A TBI.
Old Nov 10, 2009 | 11:26 AM
the_reaper's Avatar
Well its not going to be TBI for long
Motor Specs
383 , Eagle forged crank, eagle H-beam rods, Diamond forged pistons and rings JE pins 4bolt studded mains, AFR 180 Heads with ARP bolts; 8:7:1 Compression, Factory roller block, Crower roller cam 220 / 228 @50 .531" / .553 lift, Com Cams magnum roller rockers screw in studds. Moroso Deep Sump pan.
THis summer I will be changing the TBI out for a Accel Proram system with thier DFI ECM and a transgo trans controller. I have a 5" pully on the F1A to keep the boost down for now.
Old Nov 27, 2009 | 11:02 PM
the_reaper's Avatar
It lives.....
http://s625.photobucket.com/albums/t...1271847591.flv
Old Nov 29, 2009 | 04:44 PM
stoffer's Avatar
I paid my buck-o-five
congrats
