A/F questions
Old Jul 8, 2005 | 07:22 AM
Fast360Dak's Avatar
Default A/F questions
Ok, I know my truck is in need of a tune really bad..but im still curious as to what my A/F should be at idle, and cruising around town. I know ideally when in it under full throttle shouldn’t it be around 12.5-12.7 or so..
This is what im getting currently.
Idle - 12.6-13.0
Cruising (not under boost) 11.5-12.3
I’ve seen it dip all the way down into the 10's at times as well.
Around 3500 rpms and maybe 6 lbs of boost its low 11's hi 10's.
I’m running 30 # injs, and my fuel psi at idle is 30-32, with it getting up to 65-70 under boost.
I have not stayed in it long enough to see 10 psi.
So any ideas?
Old Jul 8, 2005 | 07:25 AM
hellbents10's Avatar
LS1Tech Sponsor
At idle and cruise you should be at 14.7:1
Under boost you should bet 11.8:1 or even in the 12's if you don't have enough timing to worry about detonation.
Old Jul 8, 2005 | 07:29 AM
Fast360Dak's Avatar
Ive got the crane timing retard with a 2 bar MAP sensor, so I can pull out as much or little as I want.
Old Jul 8, 2005 | 07:30 AM
Fast360Dak's Avatar
Thanks for the info by the way.
Texas5.3_1251
Mar 5, 2016 08:10 PM
projectnightcrawler
Sep 30, 2015 10:49 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
Boyes50
Sep 8, 2015 12:06 PM
