F-Body Hot Wire kit in a Truck
Old May 16, 2009 | 09:17 AM
BigCountryx's Avatar
Default F-Body Hot Wire kit in a Truck
Will the F-body Hot wire kit wortk in a truck with a returnless fuel system. Is there someone that makes a kit that will? And would it be worth doing for a boosted 6.0 (8-9lbs) with a walbro 255 in-tank?
Old May 16, 2009 | 10:23 AM
wkdivr's Avatar
The F body kit will work. I used one on mine (04). You just have to splice in the correct plug on your fuel pump module. All the wires are the same, just the physical plug is different. Easy fix. Great upgrade for a boosted combo.
Old May 16, 2009 | 11:29 AM
Cool, would it also work well if I add a magnavolt later? I think that may be the answer to the returnless system if I start to run out of fuel when in boost.
Old May 16, 2009 | 04:05 PM
wkdivr's Avatar
It should. I'm going to use a KB BAP when the time comes.
ARC
57
Feb 21, 2022 10:54 AM
wrb002
Aug 31, 2015 12:00 PM
Ketis
Jul 23, 2015 12:37 PM
black6spdz
Jul 16, 2015 01:32 AM
NuckenFuts
Jul 9, 2015 08:45 AM
