Exhaust Size question
Old Jun 29, 2009 | 08:41 PM
Default Exhaust Size question
I'm running into fitment issues, and I'm curious about something. Would I be able to run 4" to a cutout then split into dual 2" after then run into mufflers so I can run a quiet setup when I need. Most of the time and for performance I'll be rocking an open cutout. But I want the option, however I'm curious how small is TOO small.
This is all going to be on a 402ci with a s85 turbo.
Old Jun 29, 2009 | 08:55 PM
8ALTNG's Avatar
my 5" is actually quieter than it was with my 4.8/radix with the 2.5" exhaust
Old Jun 30, 2009 | 08:35 AM
silver-mod-o's Avatar
Hunt&Fisherator
Single 4" all the way out back should do it just fine. I run a 3" DP to a 4" from the bellhousing back. Flows more than plenty and sounds pretty badass if I do say so myself.
Old Jun 30, 2009 | 09:31 AM
I'm going to run 4" all the way back, and have a cutout, but I want to split it in two, possible 2"? after the cutout so when its shut it runs through the two pipes/mufflers and out the back. Reason for the dual is the tip location. It's mainly a design and asthetics, but I want the duals to be functional. But I don't want an issue if I run dual 2"
But if I think about it I don't see why not right? Since single 4" is basically the same as 2 2", however I wanted to make sure it wasn't TOO small. I may even be able to split into dual 2.25"
Old Jun 30, 2009 | 09:48 AM
BlackGMC's Avatar
Resident Retard
I would just run 4in all the way to the muffler, then just branch off to two seperate pipes after the muffler. I did the exact same thing (but with 3") I wanted dual tips just for looks.... But the extra bends and the Y-pipe defienately changed the tone of the exhaust, it took out the deep blah sound, now it is just really defined...
Old Jun 30, 2009 | 09:53 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
2" is way too small. Run at least 2.5" through duals if not 3"
Old Jun 30, 2009 | 09:54 AM
trever1t's Avatar
btw a single 4 will flow better than dual 2 and so on...surface area and restriction is higher.
Old Jun 30, 2009 | 10:51 AM
Hunt&Fisherator
Do a single 4" into dual 3" then... Make sure your Y collector flows well... You're talking about a lot of cubes and a lot of turbo.
Old Jun 30, 2009 | 10:55 AM
SpoolinChevy's Avatar
I wouldn't go any smaller than 3" on the duals personally. I have 4" all the way back from the dp, and 3" back for the muffler for the wastegate and I have minimal room between my 4" and driveshaft. You may be able to fit 2 3" mufflers under there, but I don't know if it would be worth your trouble.
Old Jun 30, 2009 | 11:29 AM
RandomHero's Avatar
Just buy my 4" corsa setup from me. LOL
