enough room to flip drivers manifold around?
Old Apr 1, 2012 | 03:51 PM
TXsilverado's Avatar
Default enough room to flip drivers manifold around?
using truck accessories? i dont have a block laying around to check for myself.
Old Apr 1, 2012 | 03:52 PM
Ferocity02's Avatar
Could talk to this guy: https://www.performancetrucks.net/fo...0/#post4894395
Old Apr 1, 2012 | 04:04 PM
i dont have that much room to work with. i'm looking to do something like this:
Old Apr 1, 2012 | 09:38 PM
kbracing96's Avatar
Only if you point them up. They won't fit pointed down on either side if you keep stock AC and PS.
Old Apr 1, 2012 | 10:52 PM
i didnt know it was possible to flip the manifold and point it down? i was hoping you would chime in. so if i flip the drivers manifold around theres room to bolt a turbo in? or will i need to add some pipe? my plan was to use 2 drivers side manifolds. on drivers it will be flipped up, and on the passenger side it would be flippd pointing down so i can run the hot pipes below the crank pulley. it's a s10 so room is tight unless i end up removing the fender wells which id rather not do. it's seeming like i may stick to the nitrous world! nitrous is easy lol
Old Apr 1, 2012 | 11:54 PM
JFOLM's Avatar
If you swap sides with them pointing down it would be what Kyle mentioned can not happen.
Old Apr 2, 2012 | 02:40 AM
yuuup. nitrous is sounding super easy right about now.
Old Apr 2, 2012 | 02:43 AM
BlackGMC's Avatar
Resident Retard
wait until you price out some Long Tube headers for that s10 swap i heard they are rathe expensive.
Old Apr 2, 2012 | 09:18 AM
no more than the kooks that i got for my silverado lol.
Old Apr 2, 2012 | 09:34 AM
how much boost can i push with a radix through a 5.3 or 6.o?
