EGT Sensor Probe Location
Old Jul 11, 2011 | 09:24 AM
Alpinestar's Avatar
Default EGT Sensor Probe Location
Are you guys running your EGT sensor before or after the turbo? I have kb's log style manifold and was thinking of putting it right at the base of the collector.
Old Jul 11, 2011 | 10:41 AM
Johnmaster's Avatar
MASS seller approved
Depends on what you are trying to read. A typical port EGT measurement is taken 1" from the head, center of the port. The farther away from that you get the cooler the reading should be.
Old Jul 11, 2011 | 10:58 AM
Atomic's Avatar
I have a gauge for that
Interesting, I thought it would be better served in the downpipe just after the turbine.
Old Jul 11, 2011 | 11:20 AM
carbongmc's Avatar
The purpose of an EGT gauge is to correctly monitor your cylinder temps to prevent melting a piston. The closer you can put it to the head on the cylinder that is at the end of the fuel rail is your best bet.
Old Jul 11, 2011 | 03:13 PM
black00chev's Avatar
Slowest turbo build ever!
In this case Id say put it on the #7 cylinder since most people seem to melt that one.
Old Jul 11, 2011 | 08:54 PM
Alpinestar's Avatar
Yea I was just thinking about putting it below the turbo flange to read exactly how hot the exhaust gas is going through the turbine. I might just go ahead and put it on the #7 cylinder bc I doubt the temperature would vary that much from right below the turbo flange.
Old Jul 11, 2011 | 09:02 PM
Atomic's Avatar
Actually it should cool considerably past the turbine, from a basic thermodynamic standpoint anyway.
Old Jul 11, 2011 | 09:29 PM
I think he means temperature wont change much from #7 cylinder to the exhaust flange at the turbo???
Old Jul 11, 2011 | 09:44 PM
Atomic's Avatar
Oh, yea, I thought he meant post-turbo. In that case no, it wouldnt change much from the collector to the primary.
Old Jul 11, 2011 | 10:02 PM
charcold-bowtie's Avatar
I would probably put it after right after the last runner runs in to the log realistcally tho.
And no, this obvsly isnt my set up lol.
