EGT Sensor Probe Location
Old Jul 12, 2011 | 10:47 AM
carbongmc's Avatar
Originally Posted by Alpinestar
Yea I was just thinking about putting it below the turbo flange to read exactly how hot the exhaust gas is going through the turbine. I might just go ahead and put it on the #7 cylinder bc I doubt the temperature would vary that much from right below the turbo flange.
If you put it closer to the flange, your going to be getting your average temps of that entire bank of cylinders, which kind of defeats the purpose of it. I had an egt gauge on a turbo eclipse and it was mounted at the flange before the turbo, and not on #1 cylinder. After remounting it in the runner for #1, there was an 80 degree difference (hotter) then before. Take that into consideration. Just because its easier to mount it at the collector, doesnt mean its better. Good luck either way bud.
Old Jul 12, 2011 | 10:09 PM
charcold-bowtie's Avatar
Right^, but what good does 1 out of 8 EGT's really do?
Old Jul 12, 2011 | 11:11 PM
TURBHOE's Avatar
i mounted mine on #7. i figure if its the hottest cyl (most people melt it first) then all the other have to be good. if you put it to far from the head and your runing on edge then you could melt something and not know you were too hot. because your thinking your at a bearly safe temp but really your cyl is 100* or so hotter and boom there goes the motor. if you want an average get 8.
Old Jul 13, 2011 | 06:15 AM
black00chev's Avatar
Slowest turbo build ever!
Are you running stock driver manifold? Wondering how hard it would be to put the sensor in it.
Old Jul 13, 2011 | 09:05 AM
Pocket's Avatar
Cast iron is easy to drill and tap
Old Jul 13, 2011 | 01:34 PM
Johnmaster's Avatar
MASS seller approved
^^^ like butter!
Old Jul 14, 2011 | 02:19 AM
TURBHOE's Avatar
yeah factory manifold. i marked it and pulled it off then drilled it.
Old Jul 14, 2011 | 02:44 PM
Ok cool... Ill plan on doing this for myself when its install time!
Texas5.3_1251
Mar 5, 2016 08:10 PM
Pontiac Derek
Sep 19, 2015 01:49 PM
creekrat
Sep 10, 2015 12:59 AM
Pimpinpete
Sep 8, 2015 07:39 PM
the owl
Sep 4, 2015 04:09 PM
