EGR block off
Old Nov 19, 2013 | 03:23 PM
GRRR65GTO's Avatar
Default EGR block off
I was wondering where I can find the block off plate for the intake manifold or what else I could use. I called the dealership and its discontinued, and parts stores dont have it like I though. And I'm obviously gonna have boost so the sticking a generic plug wont work will it? I guess Ill go check out the local junkyards too
Thanks
Old Nov 19, 2013 | 03:31 PM
Ferocity02's Avatar
I got a nice aluminum one on eBay. I machined it out and put my IAT sensor in it.
Old Nov 19, 2013 | 03:50 PM
GRRR65GTO's Avatar
Found a decent one on there, I though i looked on ebay but I guess not
Thanks
Old Nov 19, 2013 | 06:48 PM
jjc839's Avatar
I used an expanding rubber plug, it's a plug with a nut on one end, you put the plug in the hole and tighten the nut to expand it, works great. They can be found at plumbing and hardware stores, I think mine was $4.
Old Nov 19, 2013 | 09:13 PM
GRRR65GTO's Avatar
I know what youre talking about. It holds under boost?
Old Nov 20, 2013 | 07:52 AM
Bagman's Avatar
Using the same thing. Not as fancy but it works. Only running 10lbs of boost on my motor, but no issues whatsoever with plug.
Old Nov 20, 2013 | 09:29 PM
jjc839's Avatar
Ya, I only run 8psi, but when I first did the turbo I hooked up the wastegate backwards and hit 25+.....the plug held, unfortunately the pistons did not.
Pimpinpete
43
Dec 22, 2017 08:13 AM
gmcyukon
Oct 5, 2015 06:20 AM
Mark_k
Oct 1, 2015 11:17 PM
old motorhead
Sep 29, 2015 08:22 PM
trevorh1
Sep 27, 2015 08:47 PM
