Eaton TVS in action!
Old Jan 24, 2007 | 07:32 PM
  #51
Member82,817's Avatar
Originally Posted by Crash Dummy
The TVS is the next generation of superchargers , you can count on it. I seen the same blower thats on Matt's truck make almost 700 HP on 14 lbs of boost on a bone stock 5.3 with a G2-3 cam and the only reason it made such a small number was because it lifted the cylinder heads off the block and started blowing exhaust into the dyno cell. The HP curve was not even thinking about falling of at that point. I think 800-1200 HP numbers with low parasitic and temperatures will be easy with the new TVS superchargers depending what size unit is used. Look out everyone!
Wow, you sound like you have some experiance with these blowers! Good info!
Old Jan 24, 2007 | 07:44 PM
  #52
Blown2300's Avatar
Yup, that was kinda funny. Gotta get some better fasteners on that head!
Old Jan 24, 2007 | 08:55 PM
  #53
I wonder how it would run against a F1R Procharger
Old Jan 24, 2007 | 09:12 PM
  #54
Blown2300's Avatar
it would actually have decent boost below 4,000 engine rpm..
Old Jan 25, 2007 | 12:29 AM
  #55
Revolutionary's Avatar
Decent boost compared to.. hah my D1 makes boost off idle.. hmm..
Old Jan 25, 2007 | 09:15 AM
  #56
Crash Dummy's Avatar
Former Moderator :(
It had ARP head studs, its the thickness of the deck on the stock GM head that is the problem, aftermarket heads with thick deck is what it needs.
Old Jan 25, 2007 | 09:25 AM
  #57
Lord Aries's Avatar
Originally Posted by philntx
This is what is on the header above the video link:
'99 Chevy Silverado
All Wheel Drive transfer case
Stock 6.0L short block
Lingenfelter ported LQ4 heads (74cc) with Eaton light weight valves.
Comp cam XR265HR
Standard Magnuson kit with Prototype TVS R1860 supercharger running 8-9psi.
Stock throttlebody
Dytnatech headers with Corsa exhaust
4.10 gears Eaton E-locker in the front, Eaton Limited-Slip in the rear
Transmission: Mega Raptor from PATC 4L60E
No Methanol injection
No N2O
5000 lbs. curb weight
60-foots in 1.5 - 1.6 seconds!
Thats who makes my 4L80e, i have the Bionic80.... I love my transmission... Just thought i would share that. LoL
Old Jan 25, 2007 | 05:30 PM
  #58
Blown2300's Avatar
Whats your boost pressure at idle and what is it at say 6k rpm? Anywhere close?
Old Jan 26, 2007 | 07:33 AM
  #59
yurs78's Avatar
What exactly is the deck thickness? So this means that any stage III head work done to the stock 6L heads isn't good enough to hold 12#'s of boost or more with the new TVS?
Old Jan 26, 2007 | 07:10 PM
  #60
Former Moderator :(
All I know is we had stock 5.3 truck heads at 14 lbs with ARP studs (properly installed ) with MLS gaskets and the head was lifting and blowing exhaust out between the head and block. We took the heads off and you can see that they were lifting in between the studs, no leakage around the studs just in the middle between them.
