E85 fuel system for boost
Old Jun 22, 2011 | 08:57 PM
  #21
scooter k's Avatar
Originally Posted by Rat Raceway
Scott Did you ever Dyno that truck?
MAN! I wish I could get 18psi out of my Jackshaft 2300! LOL
No not yet. I need to shim the rear axle to get the pinion angle right. It is tuned I guess the best it will be via email tuning. Probably need to take it
and have it touched up. It has a few issues starting cold.
Old Aug 22, 2011 | 07:01 AM
  #22
slowec's Avatar
Hell, E85 stock vehicles have cold start issues. Reviving for more E85 boost talk.
I have 75lb injectors and I am considering adding another 255 to run e-85.
Old Aug 22, 2011 | 09:00 AM
  #23
TX Tahoe Z71's Avatar
Originally Posted by TX Tahoe Z71
I'm on the stock flex fuel pump with a kenne bell boost a pump with 75# inj at 44psi (iirc) and am at 75% IDC. Probably pushing about 9lbs.
FWIW, with the addition of the GT2-3 cam, I'm at 85% IDC now.
Old Aug 22, 2011 | 10:30 AM
  #24
slowec's Avatar
Are your injectors 75 lb @ 43 or 58 psi?
Old Aug 23, 2011 | 03:44 PM
  #25
idahoblkss's Avatar
i just got done doing a larger fuel system for my e85 set up. i went dual in tank 255's both running all the time (heard horror stories of hobb switch failing) hot wired to the back of my altinator. i did -8 line all the way to the rails upgraded to ls1 rails with a -6 return and bought some siemens 80# injectors @ 45 psi and run my fuel presure at 58 psi at idol . here is my build thread if you want to check it out ... Fuel System Build - SilveradoSS.com
Old Aug 23, 2011 | 04:20 PM
  #26
They are rated at 75# at whatever flex fuel pressure is, so 43 or 44psi, iirc.
Old Aug 27, 2011 | 12:58 AM
  #27
Midnight's Avatar
So running twin wallbro's is sufficient for an E85 conversion?
Old Aug 27, 2011 | 12:35 PM
  #28
Beatdown Z's Avatar
Laid Back
Depends on your power goals...
Old Aug 27, 2011 | 04:24 PM
  #29
idahoblkss's Avatar
They should be good for at least 800hp to the wheels on e85
Razor
Dec 1, 2015 10:46 AM
MS3Z
Jul 30, 2015 06:17 PM
lxcoupe
Jul 21, 2015 02:12 AM
4B11T
Jul 13, 2015 03:48 PM
