Duramax Intercooler tuning
Old Jul 11, 2006 | 09:25 PM
  #21
MikeGyver's Avatar
Congratulations! I know how good you feel about your truck now, compared to pre-intercooler project days. I can't wait to see how mine runs when it's cooler out, I'm sure you feel the same. Your truck will probably adjust to the timing and get rid of the KR after a few drives. You probably could have gotten away with even more than 16 degrees. Good job!
Old Jul 11, 2006 | 09:29 PM
  #22
MikeGyver's Avatar
I just reread your response to mjhoward- did you pulley down? I don't remember that. Aren't you monitoring boost?
Old Jul 11, 2006 | 11:52 PM
  #23
Whippled 496's Avatar
I was at 6lbs originaly with the whipple, then bought an 8lb pulley off of Ebay. I ran with that for a while until i put the I/C on. With the Boost drop across the I/C, it left me with about 6lbs again with the same pulley. The 2.75" pulley netted me about 8lbs before the I/C install, then the same pulley (2.75") gave me almost 2lbs less after the I/C was in. I will need to go to a 2.5" pulley to get the psi back when running through this I/C. With everything being right on the money now, i will leave it alone.....at least until cooler weather.
Old Jul 12, 2006 | 02:25 AM
  #24
Keith's Avatar
Thats pretty damn cool that you got the dmax intercooler to work on your truck. Now it's time for some bigger injectors and more boost.
Old Jul 12, 2006 | 11:10 AM
  #25
kbracing96's Avatar
so, I gota ask, how much MORE did the D-Max cooler endup costing you then Whipples cooler?
Old Jul 12, 2006 | 11:20 AM
  #26
03sierraslt's Avatar
How many hours do you have in this as well? Just messin with ya man, I know how it is. Hey you have a air to air on a whipple using a duramax intercooler and YOU built it.
Old Jul 12, 2006 | 03:35 PM
  #27
well for a guy who is not really a hands on type of guy..LOL, i still think it actually cost me less. If i had to guess:
$215 for the I/C
$357 for the radiator
$26 for the rad hoses
$119 for the charged air pipe
$200 for the various clamps and silicone connectors
$78 for the oil cooler
$200 for misc parts (tees, oil cooler hose, bolts, aux battery tray and cables, fan shroud)
All brackets, and flanges were made by me with Aluminum from the shop.
I figure i have about $1200 invested in the whole project + my time. They wanted $1650 + shipping for the Whipple kit. I dont think i would have got near the efficiency out of the Whipple kit as i have with the Dmax I/C. It cost me more time obviously, but i think i am better off. The only very minor drawback to the project is the addition of the I/C and oil cooler into the core support stack. Now i have 5 items in the stack (oil cooler, trans cooler, A/C condensor, I/C, and radiator), instead of 3 (trans cooler, A/C condensor, radiator). This brought my ECT's up about 20*, but only when sitting still. If i am driving the ECT's are a consistant 180*, but if i sit for more than 10 minutes, they will creep up to about 195*-200* and sit there...they never go over 200* though, even with the A/C on and at idle for 15 minutes. Even if for some reason i want to go with the Whipple kit in the future (if i find a great deal on Ebay or something), i am not beyond being able just pull this stuff off and put the whipple kit on. The only thing i would need to buy would be the lower radiator hose. I think i made the right choice (or you guys pushed me in the right direction i should say), just cant wait till the temps come down a little into the 60's and 70's so i can really have some fun.
Old Jul 12, 2006 | 05:46 PM
  #28
Excellent work! Hopefully this makes up for those frustrating days putting it together! Are high 12's in your radar?
Old Jul 12, 2006 | 06:00 PM
  #29
Leroy_454's Avatar
Glad you got it all buttoned up! Do you think electric fans would help keep the ECT down? The flexalite duramax fans look like a good setup and should be designed to pull enough air through all the items you have stacked in front of the radiator.
Old Jul 12, 2006 | 07:18 PM
  #30
Well, i think the only way this big hog is gonna see 12's is if i get a running start... . Remember, this sucker weighs about 7000lbs.. . I definitely see some sort of 13's depending on weather and what pulley is on this thing at the time. I want to get EFILive so i can change pulleys and tunes for the track, then back off when i want to go on a road trip. I will be happy to see any kind of 13 second run.
i am not sure about Efans yet, i may look into that if the temps get worse for some reason, but i dont have any problems with how they are right now. I did see where one of the mods over on the diesel page installed a set and really like them.
