Duramax intercooler install has begun
#62
My sensor is 3/8" NPT. This one....
http://www.diyautotune.com/catalog/o...tail-p-62.html
My tubing is pretty thin, maybe .063 or 1/16". Its the tubing they sell in the kits on Ebay. Seem like pretty good kit except for the hose clamps which imditching for some t-bolts.
#63
Okay, hope you guys arent getting sick of pictures yet. Here are some of the completed oil cooler and custom bracket I made to hold it. It worked out perfectly.
here is the bracket....
Here are some shots of the cooler installed. There are 2 smaller 90* clips down below that hold the cooler to the bumper clips to keep it from moving......
Gettin closer, to be continued.......
#65
Originally Posted by Manic Mechanic
How much are the kits and do you accept Pay-pal.
LOL,
Vernon
LOL,
Vernon
Made it out of a piece of 2"x3" aluminum angle. Took about 10 minutes to make and 30 minutes to paint.
#67
Originally Posted by Jamesbond2509
WOW You better get the 12lb pulley out. Don't forget to get a smaller belt. Im betting on mid to high 12s with a good tune.
LOL i hope you are talking about yourself....cause the only way this truck is going to see 12's is if i have a 70mph running start...LOL. And yes, i have been looking at getting a smaller pulley....one because im anticipating a little boost drop and two because i hope i can get the charge cool enough to justify it.
#69
Okay guys, your gonna have to bare with me here because im a little aggrivated. I spent all day getting the pipe ran (and it was a bitch). Had some very tight spots to deal with but i got it all ran and it looks good. I topped all the fluids off and cranked it for about 30 seconds until i had oil pressure. It started right up and idled a little rough for just a second or two then leveled off and sounded fine. I went out to have a look under the hood while it warmed up and noticed that every single 90* silicone connector i had was pulled almost all the way shut from the vacuum and they are 3 and 4 ply too. I know some people here said to be careful, but i thought i had enough pipe in the 90's that it should be fine.....NOPE. So whats my option now? I dont think i can get away with aluminum 90's because the radius' are to large, thats why i used the silicone ones. Man, what a bummer....i wanted to take this thing for a ride today. After this happened, i turned the radio off with my 1/2" socket wrench and came inside. Nothin like workin all day in 90 degree heat just to end up like this. SO is there a place i can get some really strong 90's? Not sure what to do now......besides cool off......
#70
You know I have been thinkng that some of this may be related to the location of the by pass in the blower. I wonder if the by pass was hooked up between the outlet side of the intercooler if it would make a difference? I will only have one 90 that is silicone and with both pipes in the 90 it CANNOT collapse, now mind you the 90 that I have is different from others in its design. Its hard to describe, Ill get some pics of it. It is a 3" - 2 1/2" 90, if you look in some of the pics in my thread youll see it. I know this doesnt help you, just a thought about the by pass.
