dual wastegate thought
Old Feb 14, 2010 | 09:52 AM
MGMC's Avatar
12 Second Club
Default dual wastegate thought
What would happen if you had two different spring sizes in each (10.1psi & 11.6psi)? would you boost the average of both springs? just something i though about trying since i only have two of one size spring.
Old Feb 14, 2010 | 09:57 AM
1989k1500's Avatar
I could be wrong but I dont see how that would work.
One gate would open at 10.1. Youd only make more if you were getting boost creep before because that gate couldnt keep up, then youd get the 11.6 before the other gate opened.
Old Feb 14, 2010 | 10:04 AM
MGMC's Avatar
12 Second Club
yeah duh, brainfart. the higest spring is the pressure i would see
Old Feb 14, 2010 | 10:06 AM
MGMC's Avatar
12 Second Club
i need to buy another large yellow dammit
Old Feb 14, 2010 | 11:30 AM
Casey2323's Avatar
Default wastegate
I have run dual gates for a while... its tough combo .... all you need is more spring...... or get a 15.00 controller....
Old Feb 14, 2010 | 01:24 PM
quicksilverado's Avatar
The lowest spring is the pressure you would see.
Old Feb 14, 2010 | 02:07 PM
Wilde Racing's Avatar
How do I change this text
Unless the smaller springed gate was unable to flow enough to bypass, then boost would be erratic..
Old Feb 14, 2010 | 06:43 PM
MGMC's Avatar
12 Second Club
In my case i would see the higher of two springs due to one wastegate not flowing enough for my set-up. I was over-boosting with only one wg.
Old Feb 14, 2010 | 06:44 PM
MGMC's Avatar
12 Second Club
agreed, this was a dumb question on my part
Old Feb 14, 2010 | 07:39 PM
La Tu Papi's Avatar
Banned
sell smaller gate, buy larger 44mm gate. Problem solved
