Drilling TB blade in order to increase airflow at idle?????
Old Feb 21, 2018 | 11:41 AM
  #21
smokeshow's Avatar
Mod with training wheels
These days if you bring up drilling a hole in a drive by wire throttle, you're just asking to get yourself (or your tooner) bashed on. You already have a hole in your throttle body; it's 90mm wide and the size is continuously variable.
Old Feb 21, 2018 | 04:27 PM
  #22
madmann26's Avatar
Bwahahahahahaha
Old Feb 21, 2018 | 05:30 PM
  #23
03sierraslt's Avatar
Originally Posted by Kws82590
Lol in all honesty he has tuned my truck more times then i can count and has always done a great job
Well then maybe this simple task put him above his comfort zone. No reason to drill on your setup.
Old Feb 26, 2018 | 10:52 AM
  #24
KHester84's Avatar
Point your tuner to this efi live thread...seems like you may need to drill the TB on big n/a builds but this build seems fairly mild.
EFI Link
Old Feb 26, 2018 | 12:59 PM
  #25
Last Call's Avatar
TOTM: January 2007
On DBC, I've had to drill larger holes. Especially on those cheap aftermarket TBs.
On the DBW, there are a few idle effective area settings that need to be increased to allow the blade to open more at idle OR fudge the scalar (smaller).
I agree with everyone else though. no reason to drill a hole in a DBW TB.
Old Feb 26, 2018 | 01:35 PM
  #26
KHester84's Avatar
has anyone ever had to or heard of having to drill a hole in there TB in order to increase airflow so truck will idle correctly after installing a turbo and cam?
What exactly is your truck doing? Surging? Stalling? Takes a long time to get down to the desired idle rpm?
Old Feb 27, 2018 | 11:34 AM
  #27
About20ninj45's Avatar
Cold blooded
Old Feb 27, 2018 | 11:42 AM
  #28
Kws82590's Avatar
only a issue during start up it will stumble and act like it’s gonna stall but after a couple seconds it clears right up and is perfectly fine after that
Old Feb 27, 2018 | 03:04 PM
  #29
Has he tuned running airflow tables? What’s timing doing when this happens?
I’ve tuned large cam stroker motors that started and idled fine with no hole.
Old Feb 27, 2018 | 03:11 PM
  #30
Kws82590's Avatar
i will have to ask him he says he thinks it’s somethjng todo with a CAT check???
