Done w/ the Front Single
Old Sep 30, 2009 | 11:04 AM
  #101
LsxCody's Avatar
Originally Posted by slowlsx
Another cam? I thought u had already installed the new cam? Or your putting another one?
What size injectors are you running?
I'm guessing 60lbers and a single walbro won't be enough for a 6.0 and about 15psi?
The 60s will be fine but I doubt a single walbro will be enough
Old Sep 30, 2009 | 05:18 PM
  #102
Mort's Avatar
Will you be packaging the A/W I/C separately? Maybe you could PM me the details.
Do you have a feeling when and if the I/C may become a restriction?
Keep it coming.
Old Sep 30, 2009 | 08:07 PM
  #103
tarinitup's Avatar
9 Second Truck Club
Originally Posted by FarmTruc
Had it on the dyno, made more power, but still not done, couldn't finish the entire session.
Truck is out of fuel!!! The truck wouldn't handle 8.5/9psi and injector duty cycle was at 122%, but I think the fuel pump is failing. The truck is hard to start sometimes.
But, power did go up. 525hp at 8.5psi, it was a tad colder today, so that helped.
I tried 12psi real quick and the a/f ratio was definitely lean up top.
I've been driving it on the street with 12psi, but I don't stay in it, the dyno loads it much more than the street can.
anyway, back to the fuel system.
I'll change out the pump, if not, I'll look into twin walbros, but I know 1 a1000 will do it.
I might just leave it at 8psi and be happy, but I know it has a lot more left with some fuel added.
Great results. Let me know if you want a test mule with a 408 ready for FI.
Old Sep 30, 2009 | 08:19 PM
  #104
Matt G6007's Avatar
yeah when did you say that you were going to test out a 408???
and r u going to use the same kind of setup???
Old Oct 1, 2009 | 12:01 PM
  #105
Matt G6007's Avatar
what size e-fan is that in the kit and what do you use it for the trans collor or what???
Old Oct 1, 2009 | 08:18 PM
  #106
$nake Charmer's Avatar
that looks good man... im actually moving my sts turbo kit upfront right now... any tips???
Old Oct 6, 2009 | 01:53 PM
  #107
FarmTruc's Avatar
Performance Trucks Sponsor
here are some pics of the kit out of the truck.
pics are more detailed than before.
http://www.ls1truck.com/forums/pics-...tml#post315977
Old Oct 6, 2009 | 09:02 PM
  #108
TURBHOE's Avatar
looks good! did you ever figure out what size downpipes you could fit in there?
Old Oct 14, 2009 | 08:50 PM
  #109
Matt G6007's Avatar
what kind of cam r u thinkin about running on the 408 build up???
Old Oct 14, 2009 | 09:10 PM
  #110
GMCtrk's Avatar
still waiting to see what KB has in store to rival this
