Does Anyone Have a VE table for a 6.0 with a Supercharger Please send
#21
Originally Posted by Jamesbond2509
Are you using the Saturn Ion 2 Bar sensor from the dealer? Which table is this adjustment required. Please Advise.
Thanks
Thanks
If you look it up on one of those sites it shows that it is a "Manifold Pressure Sensor" for supercharged 2004 Buick Regal/Park Avenue. So that's what I would specify if you have a dealer look it up.
AutoVE Tutorial>Create AutoVE Map>step 11- add the extra labels here or you can edit the Map's properties if you have already created it.
#22
Thanks
Thanks
#23
Originally Posted by kbracing96
As for the table to change in EFILive, it's the MAP Sensor Scaler table {C6304}. You need to take a before MAP reading from the Flashscan at key on engine off so you can match it up after you install the new 2bar MAP. EFILive sayes 190 for the 2bar scaler, but I had to set mine to 194 to get the same 85kpa I had with the 1bar MAP.
Sorry , I'm still in Auto VE mode.
Mine ended up at 197 or 198. 190 is just a starting point. You have to do the switch and take the readings while at the same atmospheric pressure. If you take a MAP reading one day you can't use it as a reference for adjusting the MAP scaler on a different day.
Tydriver
45
Oct 23, 2015 09:19 PM
mitchellmade
Sep 27, 2015 08:27 PM
