displacement question
Old Nov 13, 2015 | 01:24 PM
TrendSetter's Avatar
i ended up with a 4.8 cause it was the cheapest one i found.
for a budget junker, i dont think it matters too much. if i wanted to set the world on fire, i would want more displacement, but nobody here will argue that a 4.8 cant hold its own with a turbo.
Old Nov 13, 2015 | 01:28 PM
Originally Posted by Ho lee ***
Oh i'm sure, but I bet he has more than just a turbo and a cam in his 4.8. I guess what i'm getting at is realistically what does it take to get a turbo 4.8 to 800hp where the rubber meets the road
check out the sloppy mechanics. if you want to play the super cheap game, a good 4.8 with ~120-150k on it (usually this puts the ring gaps in the sweet spot for boost), pac 1218 valve springs, a cam similar to a triple 12, and big injectors and pump will do it. when i did mine i threw a few bucks at rocker trunions, new timing chain, hard pushrods, and dual valve springs just to be safe.
Old Nov 13, 2015 | 01:42 PM
Ho lee fuk's Avatar
Registered User
I was thinking a KB kit with s475, a TU 1 or similar cam, 80 inj, and a big walbro of course the tranny will be swapped to the 80e
Old Nov 13, 2015 | 01:59 PM
Vortec350ss's Avatar
Yup that would get it...
Old Nov 13, 2015 | 02:59 PM
03chevytruck's Avatar
This is the setup i'm currently putting together to throw around 18-20 psi at my 2004 RCSB 210k mile 4.8. I have everything but gears & gaskets/misc parts.
KB pipes w/ BW s475.
Custom cam. BTR springs & pushrods.
LS7 Lifters.
60 lb injectors. I'm using 93 oct. no E85.
Alky Meth Kit.
Fuel rails and regulator.
Walbro 450.
FTI 3600 stall
Built 4l80e shortened driveshaft.
4.30 gears.
Tru-trac.
Moser diff cover.
2.5 Map sensor.
Old Nov 13, 2015 | 04:08 PM
George C....'s Avatar
Formerly ScreamingL
He doesnt have much
My old old 4.8 made 700 rwhp on 16 psi with a cam
Old Nov 14, 2015 | 07:40 AM
Ho lee fuk's Avatar
Registered User
how long did motor sustain that level George?
Old Nov 14, 2015 | 09:07 AM
Formerly ScreamingL
7000 miles and clutch went....then went twins on ls2
TwiZtedZ71
27
Oct 20, 2023 12:31 AM
genxhunter
51
Feb 29, 2016 03:44 PM
Tig
36
Dec 6, 2015 06:14 PM
Bigeats6.0
Nov 11, 2015 07:11 AM
Gumball waterson
Nov 10, 2015 05:48 PM
