DI Blower cam geniuses!
Old Aug 22, 2019 | 10:33 PM
ZO6Ted's Avatar
Default DI Blower cam geniuses!
You know who you are! So just wondering how much boost on a stock cam? If I invest in a fuel system and run E85. I'm talking maybe duel fuel on my Whip. 16 injectors How much boost is feasible with a stock cam. I realize that you don't bleed off boost like in a higher duration cam. A cam swap is so expensive since I won't do the labor may as well swap a 6.2. Am I wrong? Thanks gentlemen! Almost out of debt so...close to mod time in a few mo!
Old Aug 23, 2019 | 02:19 PM
Alvin@PCMofNC's Avatar
Truck Sponsor
Do you have headers or stock manifolds?
Old Aug 23, 2019 | 05:36 PM
ZO6Ted's Avatar
Stock but I will likely do 1 7/8" SE headers and either their 3" duals with quieter mufflers or a 4" single with ory and dual 3" to single 4" merge before fueling.
Old Aug 24, 2019 | 01:30 PM
randeez's Avatar
does the whipple intake have a place to put injectors - you would need some way to drive and control them? part of swapping the cam is the larger fuel lobe to up the high pressure fuel pump.
i think a few companies are starting to come out with +30% and +60% DI injectors - i dont know how much they are compared to the LT4 stuff though.
Old Aug 24, 2019 | 02:10 PM
ZO6Ted's Avatar
The intake has bosses and the fueling company has the whole setup and will mod the manifold for the 8 additional injectors. Supposedly supports maybe 1400 at the crank without a need to upgrade the DI setup if I read it correctly. All the hardware and software with instructions and support. I wish on the cam, but I just don't want to go there because the price of a 6.2 isn't that much more it seems. I would cam a 6.2 of course before installing one.
Old Aug 25, 2019 | 07:44 AM
smokinlmm's Avatar
Dam, the newer trucks are so complicated to make big power it seems...
Old Aug 25, 2019 | 07:09 PM
ZO6Ted's Avatar
Totally agree on that one! I'd give anything if I had bought a pre 14. Box stock they run their *** off but modding is a big pain! So expensive.
Old Aug 26, 2019 | 08:06 AM
Jonblarc7's Avatar
But isn't the fuel system your talking about more than a cam swap?
I just think your trying to spend all this time going around a cam swap. When all roads lead back to you doing a cam swap. If you didn't removed the heads. It really wouldn't be that bad to do a cam swap on these newer engines. For the numbers your going to shoot for. I would think you'll be back right back to doing a cam swap.
Old Aug 26, 2019 | 08:11 AM
Jonblarc7's Avatar
Pmoore4321 has some video's on the auxiliary fuel system for his L83. The only difference is he already swapped a LT1 cam into it before he decided to supercharge it. But that cam doesn't come with a bigger fuel lobe.
<iframe width="560" height="315" src="https://www.youtube.com/embed/0AFmNcH6fno" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/46uJmgT4ZTo" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Old Aug 26, 2019 | 08:14 AM
Jonblarc7's Avatar
Not sure why those didn't embed.
