Dayco Belt tensioner
#23
Yeah I went to Napa with the dayco part# and wound up with the gates tensioner which im glad I did this one looks like it will last a while longer than the maggie supplied tensioner and I still run the original maggie belt with this tensioner 100mm idlers and 2.9 pulley imagine that
#24
#25
Has anybody checked or messured the spring force of each unit to see which one has the most force to keep the belt from slipping, if not I will try to get my hands on the Gates unit and compare the two in the next 2 weeks.
#27
Interesting, I just broke my tensioner a couple of nights ago. I might go to autozone tomarrow and see if I can pick up a dayco one or something, beats ordering one off the net and having to wait for it to get here.
#28
Maybe one of Dayco's Heavy Duty tensioners for big rigs can be adapted with a 6-rib pulley and made to work on the stock accessory bracket. These tensioners are more heavily constructed and built to keep tension on 8, 10, and 12-rib belts.
http://www.daycoproducts.com/daycowe...nerCatalog.pdf
#29
I just picked up the Gates Belt tentioner and it does seem to be a better built unit, I will take some force messurements soon as I can build a test fixture.
First observations is that the Gates unit has less total travel, that could present a problem as the belt stretches under boost and you could lose tention. I will report back with pics and numers next week.
