Custom STS? what do u think?
Old May 13, 2007 | 11:35 PM
Fast_5.3's Avatar
Default Custom STS? what do u think?
I recently sold my civic and kept the turbo kit and now want to use all the parts and fab up a rear mount turbo set up. do u think this is possible? i still have the turbo, wastegate and bov. what else would i need besides a scavage pump for the oil, a t3/t4 turbo flange ,custom pipe bent to fit and a nelson custom tune.??? Any help would be greatly appretiated ... thank you
Old May 13, 2007 | 11:41 PM
Derek @ EDO's Avatar
FormerVendor
well i would think that the turbo from the civic may be too small, what size is it?
Old May 14, 2007 | 01:37 AM
Spoolin's Avatar
GFYS and STFU
That might be an understatement!!!
Your gonna need injectors, and possibly a boosta pump depending on what boost you want. Seriously I think your gonna need a bigger turbo, that things gonna max out at idle!!
Old May 14, 2007 | 03:19 AM
cpelton's Avatar
not necessarily, theres a guy i know that has a bigger turbo on his civic than what im running rear mount on my truck. Whats the specs on the turbo?
Old May 14, 2007 | 09:57 AM
Fast_5.3's Avatar
its a T3/T4 its actually bigger than the one in my oys cummins deisel
Old May 14, 2007 | 10:50 AM
ZZebes's Avatar
T3/T4 is the flange size
What is the compressor wheel, Exhaust Housing A/R, etc, etc.
Old May 14, 2007 | 11:50 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
He's saying that it's a t3/t4 hybrid like my stage III 60-1s. Still need the compressor wheel size and the A/R to know for sure, but most 5.3 kits are happy with stage I 60-1s or GT35s.
Old May 14, 2007 | 02:41 PM
vanillagorilla's Avatar
So your 60-1's have a t3 flange on them?
The way I understand it, is this, a T3/T4 has an exhaust housing of a T3 sized turbo, but the compressor housing from a T4. This allows a quicker spool up with a larger compressor wheel. The down size is that the exhaust can run out of flow before the compressor does, but that's why they're usually found in smaller displacement engines where a higher PR is needed/desired.
Old May 14, 2007 | 02:55 PM
Spoolin's Avatar
GFYS and STFU
Originally Posted by vanillagorilla
...but that's why they're usually found in smaller displacement engines where a higher PR is needed/desired.
PR...?
btw thanks for the T3/T4 explanation. Your explanation cleared up a couple questions I had running through my head, just didn't catch the PR part.
Old May 14, 2007 | 03:17 PM
PR=pressure ratio
