Custom fuel system install pictures needed
Old Nov 30, 2010 | 08:17 AM
scooter k's Avatar
Exclamation Custom fuel system install pictures needed
I just got a Lonnie's Performance fuel system and would like to see some pictures of installs you guys have done. Like fuel pressure regulator placement, where you ran your fuel lines, etc. I need some ideas on how to do it. Thanks guys.
Old Nov 30, 2010 | 08:39 AM
Go5.3tt06's Avatar
How much did you spend this fuel system?
Old Nov 30, 2010 | 08:46 AM
scooter k's Avatar
You don't want to know....
Old Nov 30, 2010 | 09:23 AM
Atomic's Avatar
I have a gauge for that
Do you mind posting a picture of the bucket you got back from him? Kind of curious...
Old Nov 30, 2010 | 09:26 AM
FarmTruc's Avatar
Performance Trucks Sponsor
Here's something you could duplicate on any intake.
It's simple, fuel comes into one side, crosses over to the other side, gets regulated, then take a return line to the tank.
Attached Thumbnails Custom fuel system install pictures needed-img_2661-%5B640x480%5D.jpg   Custom fuel system install pictures needed-img_2662-%5B640x480%5D.jpg   Custom fuel system install pictures needed-img_2664-%5B640x480%5D.jpg
Old Nov 30, 2010 | 09:48 AM
charcold-bowtie's Avatar
https://www.performancetrucks.net/fo...=418960&page=3
post 109ish,
But since u have a tvs these dont apply much^^^
Old Nov 30, 2010 | 07:17 PM
scooter k's Avatar
post 109ish,
I looked yours over. They look good but would be better if you had a TVS..
Thanks for helping.
Old Nov 30, 2010 | 07:19 PM
scooter k's Avatar
So in the rear of Passenger fuel rail, crossover to driver's, and through regulator. Does the regulator need to be mounted that close to rail or can
I remote mount it closer to brake booster?
Old Nov 30, 2010 | 08:02 PM
FarmTruc's Avatar
One thing I like to do when routing a fuel system is pressurize the fuel rails first, then regulate it. It always works out better, whether it be dual feeds or a Y block, get fuel to the rails first.
As for your question, no. It doesn't need to be that close, you can mount it on the firewall or down on the frame, whatever is easy for your setup.
Old Nov 30, 2010 | 08:09 PM
scooter k's Avatar
So I need a y-block? I guess Lonnie's kit is setup to run single feed line in.
