Cure for a sticky Radix bypass valve
Old Mar 8, 2006 | 10:55 PM
thunder550's Avatar
High on diesel fumes
Default Cure for a sticky Radix bypass valve
Ever since my alt lit on fire my bypass valve has stuck shut a few times and I have had to go in and open it up by hand, then it will work well for awhile. Is there anything that I can service on my own?
Old Mar 8, 2006 | 11:03 PM
TurboGibbs's Avatar
maybe a little spray lube on the moving components may help?
Old Mar 8, 2006 | 11:05 PM
BlownChevy's Avatar
blownerator
25 Year Member
Or just order a new one
Old Mar 8, 2006 | 11:17 PM
thunder550's Avatar
A new Radix or a new bypass valve?
Old Apr 1, 2006 | 03:13 PM
thunder550's Avatar
I have lubed the bypass valve several times with silicone spray lube, and it still sticks. Any other suggestions?
Old Apr 3, 2006 | 08:44 AM
thunder550's Avatar
Anyone?
Old Apr 3, 2006 | 02:19 PM
XLR8NSS's Avatar
Adkoonerstrator
Can you see anyplace that is looks like it's sticking and rubbing? If so maybe a very small amount of sanding on that spot would work?
Old Apr 3, 2006 | 04:17 PM
onyx's Avatar
14 Second Truck Club
sometimes mine does it also when i first start it up... after it sits for about 45 seconds it corrects itself.
it makes a crazy "whine" noise...
Old Apr 3, 2006 | 04:41 PM
vanillagorilla's Avatar
Astroglide has always done the trick for me.
Old Apr 3, 2006 | 05:21 PM
thunder550's Avatar
RADIX bypass Todd, not RAY'S DICK bypass.....
jeez.
