Crossover to manifold gasket trick stage 2
Old Jun 10, 2014 | 02:48 AM
lhenrichs's Avatar
Default Crossover to manifold gasket trick stage 2
I seem to have lost this gasket. Does any one know what size it would be to replace or should I get ahold of Rick for one that he has specifically for these?
Old Jun 24, 2014 | 11:20 AM
timmay208's Avatar
prob have to get it from them. Ive been looking for a metal gasket for that side with no luck
i also cant find a metal one for the driver side either
Old Jun 24, 2014 | 11:58 AM
TrickTurbo's Avatar
Truck Sponsor
Depends on the crossover flange.
If oring'd.
Just GM driverside crush gasket.
If flat no oring
I can get some cut
You can cut your own with exhaust gasket material.
Could also try hi temp sensor safe rtv.
Old Jun 24, 2014 | 12:09 PM
timmay208's Avatar
the make your own gasket stuff doenst last long, thats what i have on mine and its already blown out
how much do you guys sell the driver metal gasket and metal gasket for your manifold for? I called and left a voicemail with you guys
Old Jun 24, 2014 | 12:39 PM
Choda's Avatar
i used rtv on mine and its holding fine. Just make sure both surfaces are clean and flat. I used a file.
TrickTurbo's Avatar
Truck Sponsor
I will need to get some cut. Think they are 40.00 a set.
Old Jun 24, 2014 | 12:43 PM
timmay208's Avatar
yea both mine are nice and flat. im going to try to make a new one today and incorporate the factory metal ring into it
i had my driver flange CNC'd it should be pretty even. The one i made for the turbo manifold so far has held up but who knows for how long
is 40.00 a shipped price or plus shipping? and are yours metal/copper/gasket material?
Old Jun 24, 2014 | 12:50 PM
TrickTurbo's Avatar
Truck Sponsor
If you are building your own flanges
oring them for the gm Crush orings.
the gasket material I can have cut is a fiber/metal core gasket. Typical old school exhaust gasket stuff.
Copper takes the price over 100.00 a set ..
Old Jun 24, 2014 | 12:51 PM
GMCtrk's Avatar
I'd recommend just using ultra copper hi temp rtv. Should seal perfectly as long as the surfaces are flat.
Old Jun 24, 2014 | 12:52 PM
timmay208's Avatar
just straight rtv nothing else?
Ive never had luck just running RTV on anything exhaust wise unless its further down but right at the manifolds that see 1000+, rtv is only good for about 650, i usually spray my gaskets with a little copper spray or a light coat of rtv on each side
