Couple Qs regarding 02 sensor and placement
Old Oct 10, 2010 | 06:07 AM
SSZ's Avatar
SSZ
Default Couple Qs regarding 02 sensor and placement
Have a 5.3 and starting build for a turbo so i am going to need a good wideband 02 for when it is time for tuning. What do you guys recommend? Also it will be a truck manifold setup for a single turbo. Do i run two 02s after the manifolds or one in the downpipe after the turbo? I have a truck wiring harness and am not sure if one of these 02 connectors gets eliminated or what?
Old Oct 11, 2010 | 05:33 PM
02'Z71ONDUBZ''s Avatar
Are you doing a front mount in a truck, or just using truck manifolds? Regardless, you will need a bung below the driver's side manifold, and then another for the passenger side. Mine has one in the crossover on the driver's side just below the flange that bolts to the stock manifold, and another bung in the turbo log manifold on the passenger's side. For the wideband, you need to put a bung in the downpipe, that way you get a combined reading from both banks. As far as sensor placement, moisture and condensation will kill the sensors so I would weld all the bungs on the side of the exhaust pipe at the least, with the top being ideal. Use gravity to your advantage. As far as wideband's go, Innovate, AEM, and PLX are all pretty popular. I'm running the Innovate LC-1 myself. Also, have your tuner remove the rear o2's from your tune if you haven't already.
Old Oct 12, 2010 | 04:26 AM
SSZ's Avatar
SSZ
Thank you much appreciated
lucas287
31
Jan 12, 2021 06:18 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
creekrat
Sep 10, 2015 12:59 AM
Pimpinpete
Sep 8, 2015 07:39 PM
muncie21
Sep 7, 2015 09:55 PM
