Converter for supercharged truck
Old May 23, 2009 | 07:13 PM
  #31
silver-mod-o's Avatar
Hunt&Fisherator
My 258mm (10ish") CircleD was built to foot brake to 3500 RPM, and I'm guessing it'll flash a hair higher, a single disk will still give you a positive lock-up capability, but not quite the durability of a multi disk setup. I chose single disk due to my very unabusive settings for lockup, some prefer it other ways. That's why there's so many different ones built
Old May 23, 2009 | 07:44 PM
  #32
KySilverado's Avatar
I've had no experience with anything but PI. Two of them now. Went with them again on the 80e because I had no issues with the one from the 60e's. I love how the 3 disc clutches lock up. Feels like another gear shift.
Old May 26, 2009 | 09:56 PM
  #33
supercharged tahoe ss's Avatar
I put in a pi 3000 5 disk lock up launches great but a little loose for daily driving might send it back to re stall to 2800 i got the one for the 4l80 swap so you dont have to change the flex plate. talk to jack.
Old May 27, 2009 | 12:45 AM
  #34
zippy's Avatar
It's odd with the stock converter that you are only cutting a 1.9 60'. The stock converter with your setup even without the nitrous should be flash stalling to 2600rpm or higher and with the torque from your MP122 down there you should have a 1.7 range for 60' time. What tire are you running? How much timing do you have in it down low? Just a few curious questions. You should really be running very strong even with the stock converter and only having a 3.73 gear.
Old May 27, 2009 | 04:41 PM
  #35
old motorhead's Avatar
Tires are 12.8" wide and 28" tall. ET Streets. Not sure of the timing. Truck runs mid 12's at 109mph in warm muggy air. Haven't figgered the nitrous out yet. Trying to get everything sorted out without the gas first. I'm not sure what the stock converter flashes to. Truck leaves with little or no tire spin. Just thought it would leave quicker with a little higher stall.
wrb002
Aug 31, 2015 12:00 PM
lxcoupe
Aug 15, 2015 06:13 PM
ZONES89RS
Jul 22, 2015 12:35 PM
black6spdz
Jul 16, 2015 01:32 AM
Deceptarado
Jul 8, 2015 05:24 PM
