Controller problem
Old Nov 23, 2006 | 10:09 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Default Controller problem
I was making my best runs last weekend so I let my good friend make his first pass ever. After his run i find I'm going lean when I get in boost! His run was only a couple of tenths slower so it must have occured at the end of, or after his pass.
I have a 2 bar tune and MAF enabled so I was able to drive home fine, staying out of boost
Turns out the Meth controller was sucking voltage from the MAP.
The truck seems to run/sound fine-no smoke. I drove 2hrs home that evening and another 70 miles to Rick's and back without problem. We have the controller disconnected and a new one is on the way.
I've checked the oil level and it looks good, no loss or burning. This is the first I've ever heard of a controller issue, of course I have to be the first.
Lucky , huh?
Old Nov 23, 2006 | 10:40 AM
litreddevil's Avatar
Banned
glad you found it as fast as you did the elec. part of your truck can be a nightmare
MikeGyver's Avatar
Originally Posted by trever1t
Lucky , huh?
Yours is a perfect example of why I sold my alcohol injection system and installed an A/A intercooler instead. I don't want to rely on luck to keep my motor together.
Old Nov 23, 2006 | 08:35 PM
trever1t's Avatar
Every system added increases risk of catastrophic failure but if I lived in fear I'd be driving a stock setup. I'm pushing the little 5.3 to it's maximum potential, and risk exists. The benefit outweighs the risk today.
Old Nov 24, 2006 | 08:39 AM
Mort's Avatar
Cool
Maybe it would be safer to use a separate MAP for the meth kit or are you already doing that? I know it would be a little added expense but then it could not fubar your 2 bar/MAF tune.
Old Nov 24, 2006 | 10:20 AM
trever1t's Avatar
I like that idea. Thanks!
sTNT971
Sep 11, 2015 02:38 AM
Pimpinpete
Sep 8, 2015 07:39 PM
mayko
Sep 7, 2015 12:24 PM
xerox17
Sep 5, 2015 01:23 PM
