Compression ratio?
Old Dec 18, 2012 | 07:44 AM
carfreak07's Avatar
Default Compression ratio?
Stock 4.8 with a set of ls1 241 heads, what kind of compression am I looking at?
Thanks folks!
Old Dec 18, 2012 | 08:46 AM
TXSZ66AVLANCHE's Avatar
Way low 8.84:1
Old Dec 18, 2012 | 09:32 AM
carfreak07's Avatar
Wow, I wouldn't have thought that with the factory flat tops! I prolly built a big cool sounding "pig" ha ha
Old Dec 18, 2012 | 10:39 AM
Mangled03gmc's Avatar
Baltimore Whore
Yeh the 41's have a bigger chamber, intake valves then the 4.8 heads. Other then that they are the same.
Old Dec 18, 2012 | 10:49 AM
61cc compared to 66.7cc combustion chamber is where the compression is lost. I've seen lots of guy install LS1 heads on 5.3's like its some magical power adder....and end up loosing a ton of power.
Old Dec 18, 2012 | 11:06 AM
carfreak07's Avatar
They do have bigger valves though. I had some 243's but didn't wanna use them on this build. It's a pretty big charger. 80mm inducer and a 86m exducer.
Old Dec 18, 2012 | 11:15 AM
5.3/4.8 heads are good heads, after you have 2" intake valves installed.
Old Dec 18, 2012 | 11:27 AM
Baltimore Whore
The heads are fine the way they are LOL. Unless you are dead set on diff intake valves. Howmany people going in the 11-10's with stock heads? Quite a bit
Old Dec 18, 2012 | 11:35 AM
Correct they are fine the way they are, the run a engine perfectly fine. Like anything else though there is lots of room for improvement.
Old Dec 18, 2012 | 11:49 AM
Baltimore Whore
Yah wasn't trying to be a smart *** bout that either, just saying in general. lol
