compresion ratio on supercharged engine??
Old Dec 3, 2006 | 07:39 PM
shawn calvin's Avatar
Default compresion ratio on supercharged engine??
how much compresion can i run on my 383 with a intercooled pro charger running 8-9 psi
thanks shawn
Old Dec 3, 2006 | 07:52 PM
fullthrottledan's Avatar
how much or what would be best with only 9psi? If you are daily driving the truck id go with 9.5:1
Old Dec 3, 2006 | 09:01 PM
not a daily driver ,but want to run pump gas
Old Mar 30, 2007 | 12:30 AM
1SlowHoe's Avatar
Destroyer of Transmissions
Same question for you Dan. 383/15psi on 93 octane. 9.9:1 too much? 9.6?
Daily driver
Old Mar 30, 2007 | 11:37 AM
Revolutionary's Avatar
9.5 would be all I run with pump gas on that combo.. you are still going to see quite a bit of KR
Most pump gas is still oxygenated which in a f.i. world with too high Static C.R. is going to play havoc with the fueling.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Corvette454l88
Sep 1, 2016 01:24 AM
chopperloco
Jul 10, 2016 10:45 PM
2500ZL1
Jan 25, 2016 06:30 AM
thunder550
Oct 8, 2015 04:53 PM
