Choice for fi Daily driver 370/402/408...Why..?
Old Feb 11, 2017 | 12:51 PM
  #31
flatblack83's Avatar
220/232 587/578. 113+3. Rob speced it.
Pat that sounds good, any set of heads you thinking..? What about a blower spacer for temps..?
Old Feb 11, 2017 | 01:06 PM
  #32
03sierraslt's Avatar
I didnt see a big temp difference with my spacer, I think it becomes more relative the more you push it. We have the same intercooler core from 1900-2300. A good head porter, I like TEA but everyone has there favorite. You could go aftermarket casting or have them work a set of 317's and mill them a bit to bump compression. Throw some studs in it also while your at it.
Old Feb 11, 2017 | 03:40 PM
  #33
thewrx's Avatar
Forged pistons, some rod bolts, oiling improvements c6 pan if you can or accusump, arp head bolts, blue print oil pump, ls9 gaskets, reuse crank/rods, and spend saved on a good set of heads you reuse on your next project, or and spend money on good valetrain and cam that isnt going to make you swap springs every 15-25k miles.
get some traction on the rear if any money left, could port your blower snout cheap too, port match manifold to heads also.
Old Feb 11, 2017 | 04:57 PM
  #34
His cam shouldn't hurt valvetrain, cam motion lobes don't have crazy ramp rates, they are stable. Also porting the snout won't do anything unless running a 102mm throttlebody and that's just the opening
Old Feb 12, 2017 | 08:35 AM
  #35
wkdivr's Avatar
I am on this page.
Me Too.
Old Feb 15, 2017 | 08:36 PM
  #36
GREENSIERRA's Avatar
I have a 408 and would not do it with a stock block again.
2 seasons and I needed new pistons due to the piston going so far out of the bore.
My vote would be stock crank and rods with a set of .030 over pistons so a 370.
Get a nice set of heads instead of going all fancy on the rotating assembly
Old Feb 16, 2017 | 03:10 PM
  #37
Atomic's Avatar
I have a gauge for that
My vote for a FI DD engine is a stock bore stock stroke 6.0L. 0.005 overbore at most just to clean it up. You dont need huge cubes with a power adder, let it do the work.
Old Feb 16, 2017 | 03:45 PM
  #38
arthursc2's Avatar
buuuuuuuuuut
boost + cubes= huge power
Everyone likes it bigger
Old Feb 16, 2017 | 04:04 PM
  #39
Atomic's Avatar
Not necessarily. The FI power adder determines max power, the engine size just tells you at what RPM you get that power.
Old Feb 16, 2017 | 06:01 PM
  #40
madmann26's Avatar
My .040 6.0 iron block was torquey as hell off idle with the Whipple. Never had an issue internally until my mishap with a certain pulley.
That's more so because of the cam having -11 degrees of overlap.
