cc 222/224 567/668 lift on turbo ?????
Old Dec 9, 2007 | 07:29 PM
mike06tork's Avatar
Default cc 222/224 567/668 lift on turbo ?????
i have a 2006 silverado with 222/224 566/568 lift comp cams and im going to put a power master t70 will that cam work with the turbo or how will it work togerter or i can still leave it on on a 5.3 10k miles
Old Dec 9, 2007 | 08:20 PM
Stoichiometric's Avatar
What is the LSA on your cam?
It will work with the turbo, it may not be ideal. Typically reverse split cams ( 224/220) should reduce spool time. Forward split should hurt spool time but lower EGT's. If the LSA on your current cam is 114 or greater I would give it a shot.
Old Dec 10, 2007 | 02:21 AM
mike06tork's Avatar
its a 112 lsa will it work or can i even give it a try and se how it work what will happend will i mess something up or what low boost low hp and trq.
5.3Okasai
Mar 9, 2022 01:07 PM
GXPJAY
Nov 5, 2015 06:49 AM
thunder550
Oct 8, 2015 04:53 PM
chacho44
Aug 3, 2015 04:07 PM
Kaldar
Jul 27, 2015 06:42 PM
