Catch can for my procharger
Creating vacuum in the crankcase will help the rings seal better and prevent the rear main seal from blowing out in a boosted application.
Vacuum pump......
They add more power than they rob and will keep your intake free of the oily junk.
Regarding moisture in the oil, just make sure you're getting the oil hot enough on a fairly regular basis. I live in an extremely humid part of the country and have never had a moisture problem.
Rx dual check valve catch can, breather on oil fill, driver side PVC line to can, then one of the check valved lines runs to the intake manifold and the other to the inlet pipe on the procharger. Only way to get crankcase vacuum under idle and under boost without a vacuum pump.
Vacuum pump......
Alright well thanks for the ideas guys I think I have got it all sorted out now. Does the actual size of the can itself matter? other than how often you have to drain it of coarse.
