Cast driver turbo manifold. :)
Old Apr 18, 2018 | 12:27 PM
  #21
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by SUTTERERMAN85
Im sure a plate could be bolted on the pass side manifold to block it off for twins...
Yep. Can even make a plug. So to remove that non needed added volume.
Old Apr 18, 2018 | 01:57 PM
  #22
01FormulaTA's Avatar
kind of out of the loop here but whats the advantage vs the passenger side manifold?
Old Apr 18, 2018 | 03:18 PM
  #23
TrickTurbo's Avatar
Truck Sponsor
Nothing. This allows for twins to be ran.
Old Apr 18, 2018 | 04:01 PM
  #24
MrHorsepowerLSx's Avatar
11 Second Club
Twins BEZEL!! ( in a cheesy English accent )
Is the manifold touching the brake flex lines in the pic? 39mm wastegate?
Old Apr 18, 2018 | 07:10 PM
  #25
Nwfjarhead's Avatar
Is it t3 or t4?
Old Apr 18, 2018 | 07:23 PM
  #26
GMCtrk's Avatar
Originally Posted by TrickTurbo
It would be interesting to bolt up to the stock Y pipe. The cats would limit the final HP potential.
The stock pipe I am not certain all match location across the board from 99-13.
For those of us not looking for a race truck for the street it would be the ticket. Would just look for a decent amount of power, a few baby turbos, and super responsive boost for daily driving. Maintain all factory emissions if needed, super easy install. Could easily hook up any aftermarket Y pipe if need be.
Old Apr 18, 2018 | 10:30 PM
  #27
TrickTurbo's Avatar
Truck Sponsor
No it’s the angle if the pic.
Any flex line or hose would be easily moved if it was.
Yes 2 boot gate flange already in place.
Originally Posted by Nwfjarhead
Is it t3 or t4?
T4 is the casting. But could easily be adapted to a t3 turbo.
Old Apr 18, 2018 | 10:32 PM
  #28
TrickTurbo's Avatar
Truck Sponsor
Yep. Don’t think I would connect to the exact crossover location.
But one could built the section easy with some 2.5” tubing. 🤔
Old Apr 18, 2018 | 10:37 PM
  #29
TrickTurbo's Avatar
Truck Sponsor
Here’s a couple of pics showing turbine housing locations.
Old Apr 19, 2018 | 06:57 AM
  #30
Choda's Avatar
Originally Posted by EarlH
Can we get a set of DI (14+) mannies? Where is the love?
Single,?
Do you have a Single turbo kit for the 14+ gen 5 trucks??? I dont know if the bolt pattern is the same as the previous gen 4 LS stuff.
duh, shoulda went to your site!
https://www.shop.trickperformancepro...2015-Truck.htm
