Casper V-Plus Volt booster instead of BAP?
you know...now that you mention it...it did get really rich AFTER that...and I didn't even think about it being the volt booster...we just leaned it out yesterday as a matter of fact...
It works perfectly!
Plugs right in and from 70%+ TPS it boosts right around what it claims to...my gauge actually showed a 2.5 increase
I will keep an eye on this product though as I am putting together a FI setup and may need the extra umph from my Walbro 255 once I turn up the boost.
Originally Posted by BigKID
Were you seeing a drop in pressure to start with? I wouldn't think these types of pump voltage boosters would be of any benifit to a regulated setup unless you were seeing less than the regulated pressure.
Randy, are you running those twin pumps on stock wiring and fuel lines?
Mine worked flawlessly for over two years...then it took a dump.
I removed it and haven't replaced it or had it repaired.
I did like it though and probably will replace or repair it.
Very intersted after i get turboed.
