Casper V-Plus Volt booster instead of BAP?
Old Jul 13, 2007 | 01:10 PM
Superado's Avatar
11 Second Truck Club
you know...now that you mention it...it did get really rich AFTER that...and I didn't even think about it being the volt booster...we just leaned it out yesterday as a matter of fact...
vanillagorilla's Avatar
I guess there's not a whole lot of interest, because I don't think most people know what one does.
Old Jul 13, 2007 | 01:20 PM
ranwalk's Avatar
I may just wait and not install mine until I can get back with my tuner. I'm already running rich as is.
Old Jul 13, 2007 | 01:21 PM
BigKID's Avatar
It works perfectly!
Plugs right in and from 70%+ TPS it boosts right around what it claims to...my gauge actually showed a 2.5 increase
Were you seeing a drop in pressure to start with? I wouldn't think these types of pump voltage boosters would be of any benifit to a regulated setup unless you were seeing less than the regulated pressure.
I will keep an eye on this product though as I am putting together a FI setup and may need the extra umph from my Walbro 255 once I turn up the boost.
Old Jul 13, 2007 | 01:37 PM
ranwalk's Avatar
Hey Kenny, I know on mine one night out cruising, a/c was on, headlights on, I went WOT and during the initial hit, my fuel pressure dropped a good bit then climbed back up. I have only noticed that one time, but that got me interested in the volt booster. I'm running twin pumps so I'm not looking for more pressure per say, just looking to make sure if there is alot of demand on the electrical system, it wont drop pressure and go lean when I first go to the floor with the pedal.
Old Jul 13, 2007 | 02:11 PM
99RCSB's Avatar
Very intersted after i get turboed.
Old Jul 13, 2007 | 02:39 PM
BigKID's Avatar
Randy, are you running those twin pumps on stock wiring and fuel lines?
Old Jul 13, 2007 | 02:56 PM
ranwalk's Avatar
The pumps have thier own wiring coming off them to a relay I added under the under hood fuse box. They are feeding the stock fuel lines. I did not do like most guys and run a hobbs switch, both of my pumps run all the time. Been that way for close to a year so far with no problems.
Old Aug 24, 2010 | 03:34 PM
sharpshooter's Avatar
bringing up and old thread
Has anyone had any problems from running one of these?
Old Aug 24, 2010 | 03:58 PM
Superado's Avatar
Mine worked flawlessly for over two years...then it took a dump.
I removed it and haven't replaced it or had it repaired.
I did like it though and probably will replace or repair it.
