CANTON 2 gallon tank For Maggies :)
The tank is made by canton. Its for the cobra mustang but fits our apps perfectly. tank is about 160 shipped
here are dimensions for you guys to look at.
the to fit into the battery track you just get a dremel and grind down at these areas
then you will need to notch it to clear the battery bolt
i used a summit box and 0 gauge wire.
then here is a comparison.
monster cable 0 gauge left, knukonceptz 0 gauge center and summits 1 gauge on the right. Monster cable uses a plastic core which makes it look thicker but it isnt. I used the knuconceptz and its much easier to work with. the jacket on the monster cable much harder to work with
thanks blue i just painted the 2 silver tabs that were on the cover of the tank black so looks better i just need to see if i can also paint the area where the handle is at that has the metal post on the bottom. i want it to be all black so looks as much factory as it can get.
