CANTON 2 gallon tank For Maggies :)
Old Mar 4, 2008 | 10:41 AM
NORCAL TBSS's Avatar
Restricted User
The tank is made by canton. Its for the cobra mustang but fits our apps perfectly. tank is about 160 shipped
here are dimensions for you guys to look at.
the to fit into the battery track you just get a dremel and grind down at these areas
then you will need to notch it to clear the battery bolt
i used a summit box and 0 gauge wire.
then here is a comparison.
monster cable 0 gauge left, knukonceptz 0 gauge center and summits 1 gauge on the right. Monster cable uses a plastic core which makes it look thicker but it isnt. I used the knuconceptz and its much easier to work with. the jacket on the monster cable much harder to work with
Old Mar 4, 2008 | 12:25 PM
Last Call's Avatar
TOTM: January 2007
Where are you going to mount the intercooler pump? I think it need to be very close to ther tank, right?
Old Mar 4, 2008 | 12:31 PM
Restricted User
pump is in the same place as it is now. Tank you can see is in the same spot pretty much as stock resorvor.
Old Mar 4, 2008 | 02:03 PM
dhpro's Avatar
Great info thnx! Sounds like a great price...only other I looked at was the one from Trick, and it might be a bit more depending on ur application I think? R/
PS...post the exhaust when u can
Old Mar 4, 2008 | 02:37 PM
Restricted User
you can pm me for the exhaust pics.
Old Mar 4, 2008 | 02:47 PM
blue2003ls's Avatar
Looks like a nice quality product and install.
Old Mar 4, 2008 | 02:49 PM
Restricted User
thanks blue i just painted the 2 silver tabs that were on the cover of the tank black so looks better i just need to see if i can also paint the area where the handle is at that has the metal post on the bottom. i want it to be all black so looks as much factory as it can get.
Old Mar 5, 2008 | 02:53 PM
Restricted User
well top is painted all now so now no more ugly silver so matches better
Old Mar 15, 2008 | 08:02 PM
Restricted User
Just a update had it powdercoated with a black texture to make it look matched better. should have it back up and going tomm i took it apart to paint the fittings black
Old Mar 15, 2008 | 08:15 PM
supersub's Avatar
Nice set up!
