Can I peice together my own STS turbo setup? rear mount
I was highly wanting to do a remote mount setup, to free space under the bay, and I just love how they sound when the turbo spools up under the truck. What all is involved into getting the correct size turbo, piping etc. To make my own rear mount turbo setup?
Yes, they do.
Im in the research stage of piecing this thing together, Custom CAI everything, with piping, correct spec turbo, lines etc. I think I may come off better, being able to use stock manifolds and all. Also the tons of space on my 2wd under-body.
I'll sell you my STS kit for 1300.00 plus shipping. It has a t67 turbo, and no I/C. You will need to fab the pipe that enters and exits the turbo. I will get the turbo rebuilt before I ship it to you.
whats required for these kits can you use your stock exhaust mainfolds and whats recomended for the exhaust??? Any upgrades needed like injectors or so, I know a tune will be needed. got any pics of what you have and whats needed??? If sleeper passes on it pm me I might want it
You need a custom Tune, larger fuel pump and at least 42 # inj.
Also need a boost gauge, a wide band should be bought also to watch A/F ratio.
I would get a good hydraulic oil return hose made and either tap the oil pan or valve cover for the oil return..
Also get a Blowoff valve.
FMIC should be required too, they feel so much stronger/effiecent with one.
Then you'll need to address your trans to hold the extra power.
Then have fun!!
