Can this cooler help keep temps down better???
Thanks for the pics. I was wondering where to install that cooler. Would you say it was worth the upgrade?
I would say it depends on how much boost your running. Since I knew I was going to run 15 psi I upgraded to this system from the get go. my IAT's remain pretty cool for the most part and cool off another 10-15 once i keep the fans on.
I didnt have enough room to run both with the fans. since my tranny cooler was moved to under the bumper I was kinda limited on running two heat exchangers. I figured i'd have enough cooling with this heat exchanger with fans and that spacer that goes in between the blower and the manifold.
op = original post(er)
This is something interesting I found....
http://timskelton.com/lightning/race...ooler_pump.htm
slower pump speed = better heat transfer
