Cam + Radix - Can I go bigger than the GT2-3 Cam
Old Feb 5, 2007 | 08:28 PM
GoatChs's Avatar
You can make plenty of power with the GT2-3...check out my dyno.
It idles like stock, plenty of vacuum.
Old Feb 6, 2007 | 04:27 PM
BLASTER's Avatar
Just got off the phone with thunder and they recommended their blower cam. Similar to the CheatR just has a diff. exhaust lobe to minimize overlap. Too bad the kits are so expensive.
Any one try it?
Old Feb 6, 2007 | 06:13 PM
Blown2300's Avatar
Contrary to popular belief, you can run a fairly large cam with boost.
Your not going to "blow it out the tailpipe" especailly when your talking a few degrees at 0.050" Besides, getting rid of the exhaust residual is not bad!
Old Feb 6, 2007 | 06:55 PM
CHarris's Avatar
You'd be surprised....
Some blowers won't have a problem because you can continue to pulley down for boost. Take a 5.3 engine for instance... but on a 6 liter... you run out at the 2.75 pulley on the radix unless you go with a custom crank pulley. Several of us have been throught this with REAL experience.
With a bigger blower you can run any damn cam you want... lol
Old Feb 6, 2007 | 07:58 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Why would you want to bleed excess boost when its already a very precious commodaty with 112 radix on a 6.0? Its been shown time and again you have to spin it too fast to keep the boost up when adding any substantial mods to that setup. I dont know of anyone getting more then 9#s out of a cam, lt header and good exhaust radix setup on a 6.0, and thats with IATS damn near boiling by the time you hit the end of the 1/4.
Old Feb 6, 2007 | 09:31 PM
BLASTER's Avatar
I want to be able to get/keep as much boost as possible. I was getting heat soak on the dyno and thought with Lts, cam, methonal, efans i could get the power i wanted. sounds like i will have to up the boost even still and then battle with IATs again. Guess I will hit the wall with power.
Old Feb 7, 2007 | 07:01 AM
zippy's Avatar
You're exactly right. The problem with a big cam in this situation is the blower being too small for a big cam. The 112 just can't move enough air efficiently without creating too much heat when running a bigger cam.
Old Apr 15, 2007 | 08:18 PM
Holty's Avatar
Notorious BIG
i wonder if this will still be an issue with the radix 122 blower? i'm dealing with this delima as i type this.
JordanH
Aug 8, 2015 07:59 PM
CashDudeHomie
Aug 3, 2015 10:58 AM
Sexyrado327
Aug 2, 2015 04:08 PM
steves86ta
Jul 28, 2015 10:21 AM
projectnightcrawler
Jul 19, 2015 11:30 PM
