Cam + Radix - Can I go bigger than the GT2-3 Cam
Old Feb 3, 2007 | 09:17 PM
BLASTER's Avatar
Default Cam + Radix - Can I go bigger than the GT2-3 Cam
I've read that the LPE cam responds very well with the radix but can I go with something bigger in duration and lift as long as I keep the LSA up?
Could I go with something in the 22xs with a 115 LSA and no overlap?
Old Feb 3, 2007 | 09:18 PM
nightrunner's Avatar
Mr. Obvious
ive heard the vinci trucker responds well to the radix, thunder550 had it and liked it pretty well
its 216/224 not sure on other specs
Old Feb 3, 2007 | 11:09 PM
CHarris's Avatar
gotta be careful or you'll just blow boost out of the tailpipe. With the finite amount of boost the radix makes... there is a point that you cannot pully down any longer... especially with the 6.0. I ran both the Thunder CHeaTR and the LPE GT 2-3 with my radix setup. The LPE idled better.
Old Feb 3, 2007 | 11:30 PM
BLASTER's Avatar
Originally Posted by CHarris
gotta be careful or you'll just blow boost out of the tailpipe. With the finite amount of boost he radix makes... there is a pint that you cannot pully down any longer... especially with the 6.0. I ran both the Thunder CHeaTR and the LPE GT 2-3 with my radix setup. The LPE idled better.
Which one did you like (overall) better? Which one made more power.
Thanks
Old Feb 4, 2007 | 11:01 AM
old motorhead's Avatar
Not sure what the overlap is in mine (specs in signature), but the bottom end is strong. That's with a stock converter. If you're needing a cam for a radixed 6.0, don't be afraid to go bigger. Mine has a good lope at idle, but it's not too bad. Still gets 18+mpg if I don't drive it too fast. It pulls strong throughout the rpm band. The Radix will pump up the bottom end.......... a bigger cam doesn't have the low end issues that you would expect from a N/A motor.
Old Feb 4, 2007 | 11:41 AM
krambo's Avatar
I run a 216/222 .559/.566 on 115LSA. It does just fine for me
Old Feb 4, 2007 | 02:12 PM
CHarris's Avatar
Thanks
I think the CheaTR lost about 1/2 a psi of boost but power was very similar. It's all about the overlap. Less overlap = more boost.
Old Feb 4, 2007 | 03:51 PM
BLASTER's Avatar
Agreed, thats why I want to avoid it but do want to go with something a bit bigger.
Old Feb 4, 2007 | 03:56 PM
gao8302's Avatar
My blower likes the 216/224-551/551 trucker cam. No loss of boost and its got a nice lope to it.
Old Feb 5, 2007 | 08:45 AM
zippy's Avatar
I installed a 224/227 .573/.577 w/114º LSA +4. in a truck with a Radix. Aside from alot of work on getting the idle to be consistant and without having it idle high, the cam worked out well. I wouldn't say it made alot of extra power though due to the heat caused by the Radix.
